GetFoldersize commandline
English support for the software GetFoldersize
Locked
kuma_1
Post by kuma_1 »
Is there a way to get the commandline to save a CSV as it does when you use the GUI?
The format I am trying to get my data works perfectly when using the GUI and setting it to scan all files/folders and show those totals in MB on the first folder(user data folders). I am setting it to save as CSV and use a comma as a delimiter.
I have been trying to use GetFoldersize.exe -s -d0 "c:\Folder Size.CSV" "\\local\corp\users"
but this is showing each subfolder, it has a comma but the whole line is in the one excel cell and then the size in bytes.
Any advice is appreciated.
Thank you.
Nate
Re: GetFoldersize commandline
Only at the GUI you can choose how many folder levels should be saved.
I will note this at our ToDo-List to add the option to the command-line.
Please use another separator if you open your csv-files with Excel and the data will be displayed at the wrong columns.
Or open Excel first, load the csv file and Excel start the Text Convert Wizard.
Locked
