im looking to run the getfoldersize via task scheduler and generate a report so im using:
getfoldersize.exe -s "c:\log.txt" "c:\"
if I use getfoldersize.exe -s1 "c:\log.txt" "c:\" to get first level subfolder i get:
c:\documents and settings\all users
c:\programs files\getfoldersize
and so on
i just need the size for all the folders unders c:\ like:
c:\programs files
and so on
What command to use to get this? it can be done via gui but cant do it in command line.
subfolder levels
Re: subfolder levels
I could reproduce and fix the problem. Please drop me an email for a new update.
