filter shortcuts
booneyrex
filter shortcuts
Post by booneyrex »
How do I Filter out shortcuts from the Search Results. What wording or syntax should I use. I have tried *.-shortcut, *.-shortcut.lnk, *.shortcut and *.shortcut.lnk and none of them work
Re: filter shortcuts
use: *.lnk
booneyrex
Post by booneyrex »
That still gave me shortcut link in the search results
Screenshot - 12.05.2022 , 15_27_42.png (5.37 KiB) Viewed 10341 times
booneyrex
Post by booneyrex »
Thanks, I finally noticed in your picture that the Use File Filter had a box that needed to be checked. When I checked it, it worked just fine.
