Search Result Grouping Enhancement
JoBeCo
Re: Search Result Grouping Enhancement
Post by JoBeCo »
Administrator wrote: 19 Feb 2022, 10:34 Sorry, this is not possible...
Is there any chance that this will be made possible? The way it actually is implemented is not intuitive at all. For example if I sort by the number of duplicates it is ment to sort over all groups. Sorting by size sorts over all groups also while leaving the order inside the groups untouched.
JoBeCo wrote: 20 Feb 2022, 05:50 Is there any chance that this will be made possible?
No. The treegrid does not support this type of sorting.
