ANSWER:
1. Activate the option "Unicode-Support" at the main menu options.
2. Select the font "Segoe UI Emoji" at the search result window -> menu bar -> options.
AllDup:
Windows Explorer:
How to display file name emojis at the search result using windows 10?
