Duplicate Folders?
Duplicate Folders?
Could we add "Duplicate Folder" search as well in the search criteria? Sometimes I just need to find dupe folders in order to determine what does or does not need to be kept. Would be easier and quicker than having to scan through files (I would imagine)
Re: Duplicate Folders?
Sorry, thats not possible.
Is that still the case? I'd also very much appreciate if I could locate duplicate folders.
AllDup can only be used to find duplicates files.
Thank you for the information.
Since the duplicate folders in my case all emerged in the last few weeks: is there a way to limit the search for duplicate files to a date range, like "files modified after ddmmyyyy"? I have not found a corresponding possibility after studying the program interface.
Thanks very much in advance
Sorry, a filter for the file time/date stamp is not available. I will note this at our ToDo-List.
Thank you very much for the fast action.
