Any way to compare Track Duration too?
rosgr100
Post by rosgr100 »
Hi, I'd like to ask if there is any way to compare track duration while i compare file names of music files.
Thank you.
Re: Any way to compare Track Duration too?
No, thats not possible.
rosgr100
Post by rosgr100 »
Administrator wrote: 02 Mar 2020, 09:35 No, thats not possible.
Hi, is there any chance to add Duration as a Comparison criterion, it would be really helpful.
mz1888
Post by mz1888 »
Maybe just display in the search results but don't actually add to comparison? such a feature would work so great with video files too. Also, allow video file audio tracks to be compared in this way.
I will add this to our ToDo-List:
- comparison criterion sound/video duration
- add column duration at the search result
rosgr100
Post by rosgr100 »
Administrator wrote: 02 Jun 2020, 15:28 I will add this to our ToDo-List:
Thank you. This will save some time for me, because now i have to check all the results to be sure that only the tracks with the same duration will be deleted.
I have one more question. due to some audio files being one or two seconds shorter or longer although the track is exactly the same is there any chance to add a setting for percentage match for duration criterion?
there is already a column with the duration available:
rosgr100
Post by rosgr100 »
Administrator wrote: 03 Jun 2020, 18:56 there is already a column with the duration available:
Yes there is, and you are able to determine duration during the search (there is an option to enable that).
This is what i'm doing now i check them manually, but if this was an automatic process it would be way faster and easier. :mrgreen:
The new "Audio" comparison criterion:
did i miss any important media file types?
rosgr100
Post by rosgr100 »
Administrator wrote: 03 Jun 2020, 22:39 The new "Audio" comparison criterion:
Perfect!!! Thank you for this, it will save so much time for me, you rock guys.
If it is possible to add a percentage match or something like 2-3 seconds difference to be considered as equal track to others this feature will be completed for me.
Any way once again thank you for the implementation.
Screenshot - 04.06.2020 , 09_26_48.png (6.83 KiB) Viewed 70506 times
rosgr100
Post by rosgr100 »
Administrator wrote: 04 Jun 2020, 09:33 Screenshot - 04.06.2020 , 09_26_48.png
Perfect!
You are the best.
Thank you! 👏👏
rosgr100
Post by rosgr100 »
Hi,
Any chance for a release date for the 4.4.29?
Can't wait for it... :lol:
I guess this week.
A lot of work to do because of the revamp of the search method selection:
rosgr100
Post by rosgr100 »
Administrator wrote: 08 Jun 2020, 20:31 I guess this week.
Thank you for the update.
One more question.
About the option you are showing above, will this compare filenames and lengths or just lengths?
