Specific Word Search
intranetsnob
Post by intranetsnob »
Hi there,
Is there a way to do a specific word search.
For example, a root folder has numerous files however, I want to pick out all the files with a certain phrase or number.
Thank you.
Re: Specific Word Search
The select command "Select files by name" enables you to do that.
intranetsnob
Thank you for getting back.
Can you type a command example of how you would search 188 in a folder?
As slightly confused with the special character required for using 'select files by name'
Using the search pattern *188* with the select command "Select files by name" will select all files at the search result that contain the number 188 in the file name. See "Wildcards for Text": http://www.alldup.info/alldup_help/placeholder.php
