Compare method: compare only files between different source folders
Comparison criteria: file name and file content
File content: ignore exif metadata of jpeg files.
file name: compare all characters of a file name
The first source folder has only one file.
The second source folder has +50.000 jpeg files but only one file has the same file name as the file in the first source folder.
I expected that this comparison would be very fast even though I checked "ignore exif metadata of jpeg files" because, after counting all the files, it can filter out all the files from the second source folder except the one with the same file name but it took actually quiet long.
Could it be that the program isn't first checking whether the filename is the same ?
Performance question: compare by file name and file content
Re: Performance question: compare by file name and file content
the option "ignore exif metadata of jpeg files" opens every file and check for the metadata...
In the comparison criteria I also checked the "file name" option.the option "ignore exif metadata of jpeg files" opens every file and check for the metadata...
Is it possible to check whether there is another file with the same "file name" before opening the file to check the metadata ?
If there isn't another file with the same "file name" it can't be a duplicate.
Sorry, thats not possible when you use the option "ignore exif metadata of jpeg files"...
