If I start a search based on the file content using a checksum it would be a nice addition if at the end the program would save for each file the filename, filesize, last modification timestamp and the checksum to a file.
If I later on want to run a compare on the same dataset I could refer to that file with checksums.
The program would than only need to reread (and recalculate the checksum) for the files where the filesize or the last modification timestamp was changed.
For a large amount of files, I think that this would further improve the speed.
ps: Thanks for the very nice (and fast) program !
Feature request: Save Checksums
Re: Feature request: Save Checksums
Thanks for the feedback. We have noted this at our ToDo-List!
