Small icons in AllDup 4.x missing
sismeiro
Post by sismeiro »
Hi All,
I don't know if the problem is on my Windows 10 only but the 3.x version of the AllDup shows very useful icons in the context menu that aren't shown in the 4.x version (see image in attach).
2018-07-28 10_12_35-.png (18.78 KiB) Viewed 11557 times
Is it possible to correct this and show the icons on the 4.x AllDup version? Thank you.
Regards,
Luis Sismeiro
Re: Small icons in AllDup 4.x missing
(That's the right-click context-menu on a file in the Results list.)
Confirmed, not seeing any icons in Win7 either.
(My Win7 has most all "glitzy" stuff turned off, & looks like XP, if that matters.)
(Can't say offhand if I recall the icons being there in earlier v4.x versions?)
New update with context menu icons is online!
sismeiro
Post by sismeiro »
Administrator wrote:New update with context menu icons is online!
Hi, just to confirm that I tested with the 4.1.8 version and the icons look beautiful. Thank you. :)
