Hi All,
First of all I want to say that AllDup is the definitive best duplicate file finder out there. A great thank you to the developer.
Secondly, is there an option to order the folder list in the Folder Filter? I'm almost sure that verion 3 of AllDup showed the folder list was ordered and was helpful.
Also I liked the icons on the context menu when you righ click in the files after the search that were in the AllDup version 3.
Regards,
Luis Sismeiro
Folder Filter list order
Re: Folder Filter list order
The next update enables to sort the file & folder filter lists via a clickable header.
Thx for the hint!
Thx for the hint!
Hi, just to confirm that I tested with the 4.1.8 version and it worked like a charm. Thank you.Administrator wrote:The next update enables to sort the file & folder filter lists via a clickable header.
Thx for the hint!
