Resize Column Width on Initial Display
Lambda
Post by Lambda »
Is there an option to optimize the column width on the initial display of the results window, but not again later when actions are performed?
Re: Resize Column Width on Initial Display
Please deactivate the option "Resize column width automatically" at the menubar of the search result window.
Lambda
Post by Lambda »
If that option is deactivated the name and path columns initially display too small. I have to click the "Optimize column width" button to widen the columns.
At the inital display only the content of the visible rows is used to optimize the columns.
Activate the search option "Expand all groups after the search" to use all available rows of the search result to optimize the columns.
Lambda
Post by Lambda »
With "Expand all groups after the search" activated, the Path still opens 1cm wide and does not show the entire path in the first row. Clicking "Optimize column width" changes it to 18cm. Is there an option to lock the column widths so they remain the same after all searches?
This issue will be fixed with the next update (maybe today)!
Just activate "Expand all groups after the search" and deactivate "Resize column width automatically".
