Hello,
please, i try similar filters for file extension and is'nt work.
I type *.jpg,*.jpeg,*.png,*.gif,*.bmp to scan filter and program found 0 records. Filters i split via comma as is wrote in HINT.
If i type only one extension, for example *.jpg, program work correctly.
Please, can you help me, what i make bad?
Multiple filter
Re: Multiple filter
I tested your settings and found out that multiple filter entries at the include file/folder filter textbox prevents finding any files.
This bug will be fixed with the next update!
Just send me an email if you need an new update with the bugfix before the official update will be released.
Dont forget to tell me what version of alldup you use if u send me an email.
Thanks for your feedback!
Re: Multiple filter
Thanks so much. And when will be new version, you knoe?
I sent mail to your info@ mail.
