Different totals for drive C showing on main screen
English support for the software GetFoldersize
Locked
rickfr
Post by rickfr »
I just downloaded this software and I'm seeing drive C under the "DRIVES" column showing a total of 288.04 GB and 282.17 used. Yet when I scan drive C and I look at the results under the FOLDERS section on the left I see a total of only 77.57 GB. Why isn't this total amount showing the same total - 282.17 - as under the DRIVES section? I'm trying to figure out why my hard drive is full all of a sudden.
Re: Different totals for drive C showing on main screen
What windows version is installed at drive C: ?
rickfr
Post by rickfr »
Administrator wrote:What windows version is installed at drive C: ?
I'm running Windows Vista.
It looks like some system folders are not accessable for the GetFolderSize user. Try running GetFoldersize with an Admin account with full system folder access.
rickfr
Post by rickfr »
I ended up having to re-install my operating system. I was told that the hard drive was not being read properly by the computer. Everything looks fine now. Thanks for your help!
Locked
