Unable to back up large files
mtn_roadie
Post by mtn_roadie »
I'm receiving the following error when trying to back up large files (i.e., 30GB):
2010/05/01 20:28:57 - #1450 - Insufficient system resources exist to complete the requested service. [CopyFile3] (D:\vm\StandAlones\xp-production\xp-production-100gb.vhd -->> K:\AllSyncBackup\Data\2010-05-01 at 19.18.34\vm\StandAlones\xp-production\xp-production-100gb.vhd) (PROFILE: Data)
I've followed the help resources on error #1450, but have been unable to copy the large files.
General Info:
Win XP SP3, 4GB RAM
AllSync 3.4.35 Business Edition
Drive Info:
Drive D: 7200 RPM 500 GB Samsung (210 GB Free)
Drive K: 5400 RPM 1.5TB Samsung (870 GB Free)
Profile Properties:
Copy Mode: Backup
Copy Method: B
Copy Attempts: 3 w/ 5 second interval
The same error occurs no matter what drive I try to back up to, i.e., backing up to an external drive or another internal drive.
Any ideas on how to resolve this issue?
Re: Unable to back up large files
What's the size of the file "D:\\vm\\StandAlones\\xp-production\\xp-production-100gb.vhd"?
Try "Copy Method C" to copy the file. Does this help?
mtn_roadie
The file in the error listed is approximately 30GB.
Using copy method C does work. However, the file is part of a much larger backup set and I'd really not want to lose the data transfer rate I can achieve with copy method B, i.e., B=90Mbps vs C=31Mbps.
If using copy method C is the only alternative, then I'll reconfigure my backup sets appropriately.
Thanks!
Please press the button "Speed Test" at the profile porperties / file options / copy method and test the copy method C between your drives D: and K:. Please run a range test from 10.000 to 300.000 with a increment value of 10.000. Set the test file size to 999mb to get a better result.
mtn_roadie
I've went ahead and just reconfigured my backup sets and all works well enough. FWIW, here's the speed test:
5/10/2010 9:25:55 AM - Summary 999 MB test file:
5/10/2010 9:25:55 AM - Source : D:\ (Local Data Medium) (NTFS) (S0MUJ1KQ126041)
5/10/2010 9:25:55 AM - Destination : K:\ (Local Data Medium) (NTFS) (S1XWJ1KZ213153)
5/10/2010 9:25:55 AM - C 23.23s 43.00 MB/s (10,000)
5/10/2010 9:25:55 AM - C 35.69s 27.99 MB/s (20,000)
5/10/2010 9:25:55 AM - C 14.16s 70.57 MB/s (30,000)
5/10/2010 9:25:55 AM - C 14.59s 68.45 MB/s (40,000)
5/10/2010 9:25:55 AM - C 14.92s 66.95 MB/s (50,000)
5/10/2010 9:25:55 AM - C 13.97s 71.52 MB/s (60,000)
5/10/2010 9:25:55 AM - C 14.31s 69.80 MB/s (70,000)
5/10/2010 9:25:55 AM - C 14.45s 69.12 MB/s (80,000)
5/10/2010 9:25:55 AM - C 14.95s 66.81 MB/s (90,000)
5/10/2010 9:25:55 AM - C 15.89s 62.87 MB/s (100,000)
5/10/2010 9:25:55 AM - C 13.95s 71.60 MB/s (110,000) ### The quickest ###
5/10/2010 9:25:55 AM - C 14.84s 67.30 MB/s (120,000)
5/10/2010 9:25:55 AM - C 14.34s 69.65 MB/s (130,000)
5/10/2010 9:25:55 AM - C 14.70s 67.95 MB/s (140,000)
5/10/2010 9:25:55 AM - C 23.16s 43.14 MB/s (150,000)
5/10/2010 9:25:55 AM - C 16.33s 61.18 MB/s (160,000)
5/10/2010 9:25:55 AM - C 15.59s 64.06 MB/s (170,000)
5/10/2010 9:25:55 AM - C 15.25s 65.51 MB/s (180,000)
5/10/2010 9:25:55 AM - C 16.02s 62.38 MB/s (190,000)
5/10/2010 9:25:55 AM - C 20.00s 49.95 MB/s (200,000)
5/10/2010 9:25:55 AM - C 23.63s 42.29 MB/s (210,000)
5/10/2010 9:25:55 AM - C 19.59s 50.98 MB/s (220,000)
5/10/2010 9:25:55 AM - C 23.78s 42.01 MB/s (230,000)
5/10/2010 9:25:55 AM - C 23.36s 42.77 MB/s (240,000)
5/10/2010 9:25:55 AM - C 24.08s 41.49 MB/s (250,000)
5/10/2010 9:25:55 AM - C 23.61s 42.31 MB/s (260,000)
5/10/2010 9:25:55 AM - C 23.58s 42.37 MB/s (270,000)
5/10/2010 9:25:55 AM - C 24.84s 40.21 MB/s (280,000)
5/10/2010 9:25:55 AM - C 24.72s 40.41 MB/s (290,000)
5/10/2010 9:25:55 AM - C 26.14s 38.22 MB/s (300,000)
Thanks for the feedback.
Please can you run the speed test again and this time with the following copy methods and data packets:
B
C 30.000
C 60.000
C 110.000
How are the results now?
mtn_roadie
Sure thing. Here are the results:
5/10/2010 6:10:29 PM - Summary 999 MB test file:
5/10/2010 6:10:29 PM - Source : D:\ (Local Data Medium) (NTFS) (S0MUJ1KQ126041)
5/10/2010 6:10:29 PM - Destination : K:\ (Local Data Medium) (NTFS) (S1XWJ1KZ213153)
5/10/2010 6:10:29 PM - B 14.58s 68.53 MB/s
5/10/2010 6:10:29 PM - C 14.19s 70.42 MB/s (30,000)
5/10/2010 6:10:29 PM - C 13.77s 72.57 MB/s (60,000) ### The quickest ###
5/10/2010 6:10:29 PM - C 19.66s 50.82 MB/s (110,000)
Also, here is another speed test I had done yesterday:
5/9/2010 2:51:44 PM - Summary 500 MB test file:
5/9/2010 2:51:44 PM - Source : D:\ (Local Data Medium) (NTFS) (S0MUJ1KQ126041)
5/9/2010 2:51:44 PM - Destination : K:\ (Local Data Medium) (NTFS) (S1XWJ1KZ213153)
5/9/2010 2:51:44 PM - B 5.52s 90.65 MB/s ### The quickest ###
5/9/2010 2:51:44 PM - C 6.56s 76.18 MB/s (10,000)
5/9/2010 2:51:44 PM - C 7.80s 64.14 MB/s (100,000)
5/9/2010 2:51:44 PM - C 11.25s 44.44 MB/s (300,000)
Drive Info:
It seems the speed depends on the mood of the computer ;-)
If you repeat the test you should use the same settings as before. Your second test was done with a different test file size and different data packet settings. What data packet size do you use now for your copy operations?
mtn_roadie
I'm running at 100,000 bytes right now.
Repeated test w/ 999 MB Test file (30k, 60k, 110k):
5/11/2010 7:04:20 AM - Summary 999 MB test file:
5/11/2010 7:04:20 AM - Source : D:\ (Local Data Medium) (NTFS) (S0MUJ1KQ126041)
5/11/2010 7:04:20 AM - Destination : K:\ (Local Data Medium) (NTFS) (S1XWJ1KZ213153)
5/11/2010 7:04:20 AM - B 13.39s 74.60 MB/s ### The quickest ###
5/11/2010 7:04:20 AM - C 14.00s 71.36 MB/s (30,000)
5/11/2010 7:04:20 AM - C 15.44s 64.71 MB/s (60,000)
5/11/2010 7:04:20 AM - C 19.94s 50.11 MB/s (110,000)
Repeated test w/ 500 MB Test file (10k, 100k, 300k):
5/11/2010 7:09:04 AM - Summary 500 MB test file:
5/11/2010 7:09:04 AM - Source : D:\ (Local Data Medium) (NTFS) (S0MUJ1KQ126041)
5/11/2010 7:09:04 AM - Destination : K:\ (Local Data Medium) (NTFS) (S1XWJ1KZ213153)
5/11/2010 7:09:04 AM - B 6.52s 76.75 MB/s ### The quickest ###
5/11/2010 7:09:04 AM - C 7.09s 70.48 MB/s (10,000)
5/11/2010 7:09:04 AM - C 6.83s 73.23 MB/s (100,000)
5/11/2010 7:09:04 AM - C 13.27s 37.69 MB/s (300,000)
Similar, but moody ;)
