How do I sort results by size (column)?
thoste
Post by thoste »
I would like to sort the result list by size.
Unfortunately the column is not sortable as usual when I click on the column header.
Is there another way to perform a size sort?
maybe this funtion should be included in the next release?
Thomas
Re: How do I sort results by size (column)?
Sorting by size is possible. If the size is shown for each file, clicking on the size column sorts only the files of each group and not the files of all groups together.
