Auto Sync
aclendenen
Auto Sync
Post by aclendenen »
Is there a setting to monitor folders and sync them to another folder, but have it run all the time instead of on a schedule?
I want to monitor the same folder on four servers and copy any added files to another folder on a server. So if someone creates a file on the monitored folder, have it copied to the other folder immediately.
Regards.
Re: Auto Sync
Sorry, folder mirroring in real-time is not possible with AllSync.
sirono
Post by sirono »
of course it is,
just set the interval to one second.
that's near real time.
but good enough for most purposes...
