Hello,
When i do a backup or sync with the trial software (home or Prof) it seems to work until the very end when this error appears. "The folder 'H:\System Volume Information' couldn't be created. (#5 - Access is denied.) (PROFILE: Test1)" and this error as well "12-13-2004 22:56 - The folder 'D:\System Volume Information' couldn't be created. (#5 - Access is denied.) (PROFILE: Test1)" D: is the source drive and H: is the destination drive.
Thanks for any help on this.
Configuation
Re: Configuation
The folder 'System Volume Information' is a system-folder of windows and stays on every root of a partition. please filter this folder to avoid this errors. you also can filter all folders with the attribute "System" to avoid such problems. check the profil properties "folder filter" for this settings.
Regards
Michael Thummerer
Regards
Michael Thummerer
Configuration
Thanks Michael
That solved the problem. This is great software. I plan on purchasing a copy.
THanks again.
THanks again.
thanks Michael
