I am using the "data protection" feature for a 1:1 copy. The backup folder names are created in the default format: Profile [yy_mm_dd hh_mm_ss]
I would prefer a different format for the folder name, but I cannot figure out how to change the format. I tried changing the copy mode to "backup" and then changing the format in the "backup options" section, then changing the copy mode back to 1:1, but that did not work. Is there a way to specify the format for the folder names with the data protection feature? If not, could this be added to a future version?
Thanks!
How to Specify Folder Name for Data Protection
Richard Drdul
Vancouver, BC
Vancouver, BC
Re: How to Specify Folder Name for Data Protection
Sorry, this is not possible now.
Yes.If not, could this be added to a future version?
