False photo duplicates
Sternwheeler
Post by Sternwheeler »
I have a group of 305 photos, .bmps and .png files that the similar photo search claims are duplicates, but are not. I mean they are not even close. I raised the setting from 95% to 100%, but still get the same bogus group. Anyone had to deal with this?
Re: False photo duplicates
Try another Comparison Method when using the search method Find similar pictures.
pau
Post by pau »
Same issue here.. I have tried with bHash Fast and bHash Precise (100% match, 256x256 pixel, 256 bit)
Try using a different comparison method than bHash.
