Hi
I have set up a profile that syncronises some network mapped drives.
When I manually run it all is fine but if I schedule (I am using the Business Edition) this profile to run I get the following errors in the log.
6/09/2005 8:55:01 a.m. - ERROR: The source folder 'H:\' couldn't be found: (#0 - The operation completed successfully.)
6/09/2005 8:55:01 a.m. - --------------------------------------------------
6/09/2005 8:55:01 a.m. - ERROR: The source folder 'I:\Documentation' couldn't be found: (#3 - The system cannot find the path specified.)
Hope someone can help
Cheers
D
Schedule Sync not working for Network Mapped Drives
dd@paradise.net.nz
Re: Schedule Sync not working for Network Mapped Drives
Which version of AllSync do you use? Do you run the scheduler as a service?
dd@paradise.net.nz
dd@paradise.net.nz
