What happens when a file can't be copied?
Let's say that we have a file on the source, and it is newer than the file with the same name on the target. If an error occurred during the copy operation, and the file could not be copied from the source to the destination, will the old copy remain in the destination or will the file simply be missing?
Re: What happens when a file can't be copied?
This depends on the used/configured Copy Method and Data Protection option. The destination file will be deleted and lost if you use the Copy Method C and the Data Protection option "Permanently delete items".
