When you do a Picture search, thumbnails as named as *.png.
But in fact the output thumbs (the actual files) are *.bmp.
Is there a particular reason for that?
(I only ask because some softwares notify you of such discrepancies.)
Re: Picture Search, thumbnails named as .png
Sorry, i dont understand the problem?
When you do an Search Image
When File Preview is enabled
When you scroll down the list of duplicates
As you come to each duplicate group
Thumbnails are generated (in a place like \temp\GUID...)
But are actually (physically) .bmp files (not .png files)
IOW, the file extension is incorrect based on what the file actually is.
(Now, granted, this does not affect AllDup's operation in any way.)
Just wondering if there was some reason that the files are named *.png rather then *.bmp?
They are named *.png because the thumbnails are created and saved as png picture files.
That is fine - if they were, but they're not.They are named *.png because the thumbnails are created and saved as png picture files.
AFAICT, they are .bmp.
From a set of AllDup ("temporary") generated ".png" (thumbnail) files (plus a separate .png thrown in for good measure [for file.exe]):
C:\out>exiftool *.png | grep -i "file type"
File Type : BMP
File Type Extension : bmp
File Type : BMP
...Code: Select all
C:\out>file.exe -m C:\BIN\UNIX\magic x*
xxx-a-REAL-png.png; PNG image, 800 x 828, 8-bit/color RGB, non-interlaced
xxx.png; PC bitmap, Windows 3.x format, 200 x 24 x 24Win7, AllDup Portable, aHash algorithm.
I have found the error in the code. The problem will be fixed with the next update. Many thanks for the tip!
