Enhancement: Save column widths of Search Results
allduperocks
I want to manually set the column widths in Search Results and have AllDup always use them. No need for AllDup to calculate them each time.
Re: Enhancement: Save column widths of Search Results
I added the search result option "Save & restore column width" to the ToDo-List.
allduperocks
great, but when are we like to see this? and in any case where does it fit with other more/less urgent fixes/enhancements?Administrator wrote: 05 Oct 2023, 10:15 I added the search result option "Save & restore column width" to the ToDo-List.
There is no fixed time frame for when the user requests from the to-do list will be implemented.
