Hi
Great product thanks for this
I have 5-6 duolicate files for photos due to disk save
But even i choose different options like keep first or last Alldup chooses broken files
How can i choose solid ones?
Thanks again
Why does it choose broken picture files?
Re: Why does it choose broken picture files?
Does the program see corrupted duplicates as different photos????????
Have a couple sample pictures you can link to?
What determines, how are you defining, "corrupted"?
Like this one and also totally blank and black photos.
But i noticed afterwards that good files are successfully selected(some files have 8-10 duplicates) and broken ones are also selected separately
- Attachments
- IMG_3197.jpeg (32.03 KiB) Viewed 18683 times
So there are thousands of corrupt files.
Is there a way to choose them?
The ones at the left are no problem the ones that has line on them are all detected as different files.
- Attachments
- IMG_3210.jpeg (27.45 KiB) Viewed 18671 times
