Select Options: Not 'Just the Largest'/'Just The Smallest'
no options for these (or indeed other similar because all/most Select options are for '... except ...' : NOT the opposite.
now, i suppose that now i have found the 'Invert Selection (ONLY in the Select Menu Option - NOT in the Select dropdown!, i could use that to achieve that
especially if that sm bug is fixed and that 'Invert Selection' option is added to the drop-down like it should have been
Select Options: Not 'Just the Largest'/'Just The Smallest' ...
Re: Select Options: Not 'Just the Largest'/'Just The Smallest' ...
Right-click on the select toolbar and activate the "invert selection" button.
sm bug?
sm bug?
as i TRIED to point out, that (important/useful) option/function is NOT on the 'normal' 'usual' Toolbar Select option drop-down!!
Only on the Select MENU Bar
the Select Options - Select Smallest/Select Largest should explicitly be in the list of Select OptionsAdministrator wrote: 03 Oct 2023, 06:46 Right-click on the select toolbar and activate the "invert selection" button.
(at the same time you could add the missing Invert Selection option)
