Copy Methods
vp
Copy Methods
Post by vp »
I have been using AllSync for a few days, and the backups are really slow. My needs are as follows: I am backing up a remote site (over VPN) to a local hard drive (let's call it "task X"), and I am also backing up a local drive to a NAS on the local network (let's call it "task Y"), both with copy method B, which is the default for Windows 2000.
I think I could save a lot of time by unchecking the "Overwrite file if the content of the files is different" option. With this option enabled, AllSync must scan each entire file for differences, wasting precious time. If the program doesn't check contents, each file check will take almost no time, no matter how large the file is, unless it actually must be copied.
Is the above theory correct?
Second, your statistics show that copy method B takes significantly longer than the others over a network. I don't want to lose all interactivity, so I don't want to use method A. I also noticed that method C takes longer than the others with a USB stick.
Which method do you recommend (i.e. which is fastest) for "task X", and which for "task Y"?
Assuming you're going to say method C, what settings should I use? Of course no pause, but what would be the optimal data packet size?
Thanks
Re: Copy Methods
If the program doesn't check contents, each file check will take almost no time, no matter how large the file is, unless it actually must be copied. Is the above theory correct?
Yes.
For "Task Y" i would use Copy method C. For "Task X" i don't know. You have to test the VPN with Copy method B and C.
To find out the optimal data packet size you must do some copy tests with your connection (VPN, USB, Wireless...)
vp
Post by vp »
Can you provide more technical information about copy methods A, B and C?
which technical informations do you mean? the name of the used APIs?
vp
Post by vp »
Yes, that would help. I'd like to do research on which method would work better for me in various situations. Thanks!
copy methode A uses the API "copyfile"
copy methode B uses the API "copyfileex"
copy methode C uses the API "CreateFile"
more infos about the APIs:
http://msdn.microsoft.com/library/defau ... ctions.asp
vp
Post by vp »
Thanks!
vp
Post by vp »
What is the maximum packet size possble? What is the significance of this number, and are there limitations to packet size based on protocol or other parameters?
vp wrote:What is the maximum packet size possble?
At this time its limited to a max. value of 999.999 bytes. If you need more.
This number specify the data packet size used to read from the source file to the memory and then write from the memory to the destination file.
Maybe, i think a packet size of 999.999 bytes will not very usefull with a slow modem connection of 64kb....you have to do some copy tests to find the optimal packet size.
vp
Post by vp »
The Ethernet maximum packet size is 1500, so is it perhaps pointless (or even counter-productive) to set the value any higher than that if transferring between computers?
Maybe...have you tested this value (compared with the standard value)? Any differences?
vp
Post by vp »
Give me some time and we'll see...
