Is there a way to find and select all photos with checksum errors?
I have this need because after a Nas restore I have thousands of them and it is impossible to select one by one selecting the reported on the log created by the search method\find similar picture.
Thanks for your help
Find and select all photos with checksum errors
Re: Find and select all photos with checksum errors
No, that's not possible.
Thank you for the prompt reply.
Maybe in future version the programmers can add this feature since AllDup already finds the photos with checksum errors maybe it won't be difficult to add this option to the Search Method.
Thank you
Thank you
What is a "checksum error" in a photo?
Is that where AllDup logs something (like) "could not read the final 1800 bytes of xxx.png" ?
If a picture file is corrupted and cant be loaded by AllDup.
Yes, but sometimes I'll catch something like:
And if that's what he's after...
That can occur with in a Context scan, when Ignore metadata of JPEG/CR2 files is also enabled.
ERROR: Could not find the end of the image data (EOI) at the last 18000 bytes of the file 'T:\+o._e-fat-e-ccc-2\070499\00287.jpg'!That can occur with in a Context scan, when Ignore metadata of JPEG/CR2 files is also enabled.
