Page 1 of 1
Find and select all photos with checksum errors
Posted: 20 Apr 2023, 13:31
by gfg
Is there a way to find and select all photos with checksum errors?
I have this need because after a Nas restore I have thousands of them and it is impossible to select one by one selecting the reported on the log created by the search method\find similar picture.
Thanks for your help
Re: Find and select all photos with checksum errors
Posted: 20 Apr 2023, 18:44
by Administrator
gfg wrote: 20 Apr 2023, 13:31
No, that's not possible.
Posted: 21 Apr 2023, 15:34
by gfg
Thank you for the prompt reply.
Maybe in future version the programmers can add this feature since AllDup already finds the photos with checksum errors maybe it won't be difficult to add this option to the Search Method.
Thank you
Posted: 25 Apr 2023, 02:59
by therube
What is a "checksum error" in a photo?
Is that where AllDup logs something (like) "could not read the final 1800 bytes of xxx.png" ?
Posted: 26 Apr 2023, 07:56
by Administrator
therube wrote: 25 Apr 2023, 02:59
If a picture file is corrupted and cant be loaded by AllDup.
Posted: 26 Apr 2023, 21:51
by therube
Yes, but sometimes I'll catch something like:
ERROR: Could not find the end of the image data (EOI) at the last 18000 bytes of the file 'T:\+o._e-fat-e-ccc-2\070499\00287.jpg'!
And if that's what he's after...
That can occur with in a Context scan, when Ignore metadata of JPEG/CR2 files is also enabled.
