Page 1 of 1
Problems with filters
Posted: 06 May 2021, 16:19
by Ivaneck
Hello,
Please, how this case can be explained? :
This folder, \System Volume Information, is filtered, as you can see here:
I have a similar case with a file, D:\Files\PCrypt.VCdsk. It contains an encrypted volume. This volume is always mounted as the P: disk unit. At 300 GB, it is not a candidate to be synchronized every day. It is better to synchronize its contents.
To make with AllSync the backup of this file, I mount E:\Files\PCrypt.VCdsk, the file in the AllSync's 'Destination' unit, as Q:. Then, I synchronize from P: to Q:. In this context, D:\Files\PCrypt.VCdsk and E:\Files\PCrypt.VCdsk should be excluded from any Synchronization process:
, but I get errors and I'm unable to set the filters properly:
I would be very grateful if you could give me a hand with these questions.
Joan
AllSync 3.5.142 Business Edition
Re: Problems with filters
Posted: 06 May 2021, 19:29
by Administrator
The pictures at your post are not visible...
Why do you want to exclude files from the drive D: and E: if you synchronize files from P: to Q: ?
Posted: 06 May 2021, 20:28
by Ivaneck
Excuse me. Repeating post from here, with images as attachments:
Hello,
Posted: 06 May 2021, 20:29
by Ivaneck
Joan
Posted: 06 May 2021, 20:30
by Ivaneck
Administrator wrote: 06 May 2021, 19:29 Why do you want to exclude files from the drive D: and E: if you synchronize files from P: to Q: ?
These files in D: and E: are containers. They contain encrypted disk volumes, mounted as P: and Q:
VeraCrypt - Creates a virtual encrypted disk within a file and mounts it as a real disk.
https://www.veracrypt.fr/code/VeraCrypt
Perhaps with pictures it will be easier to understand the issue. If not, please do not hesitate to ask any questions you may have.
Posted: 07 May 2021, 07:29
by Administrator
We tried to reproduce this error, but our filter is working fine:
Deactivate the 2. option at the rules for deleting files and folders:
delete rules.png (5.13 KiB) Viewed 54771 times
Posted: 08 May 2021, 00:30
by Ivaneck
It works!! Thanks!
