Page 1 of 2
Search Result Grouping Enhancement
Posted: 01 Jun 2020, 10:52
by mz1888
Here's some possible enhancements to the result presentation:
1. Additional grouping by folder structure, for Folder1/Sub1 and Folder1/Sub2, introduce additional grouping by Folder 1, with no % Match, but with Size and # duplicates
2. Allow path to be the first column
3. Allow sort path by ascending/descending path structure. Example: Folder1, Folder1/Sub1, Folder1/Sub2..., Folder N/Sub N. As of now, the path order does not appear to provide any reasoning, perhaps just how comparisons were computed?
4. Sort by % similar by the absolute difference of the min and max. Or, just allow path sort would suffice.
As of now, it's difficult to use the search result page as is to go over the large dataset, pinpoint to largest subset by path, re-open another instance of AllDup, re-run result using same param, perform deletes, go back to the original instance, re-run to refresh, move onto next largest subset. I've also reviewed other dedup apps and all have the same readability issues. I'd prefer AllDup to be the best and only app to use and recommend to others.
Re: Search Result Grouping Enhancement
Posted: 01 Jun 2020, 12:09
by Administrator
mz1888 wrote: 01 Jun 2020, 10:52
The sorting of the path column works fine:
Posted: 02 Jun 2020, 08:50
by mz1888
Yes that's a very ideal case where it works.
However, in reality, similar dups come in this way:
It makes me wonder how the comparison is done because % similar is non-directional. So is it up to the sequence of discovery aka ascending folder structure?? Thanks.
Posted: 02 Jun 2020, 15:32
by Administrator
What column was sorted at your screenshot?
Posted: 02 Jun 2020, 21:23
by mz1888
Administrator wrote: 02 Jun 2020, 15:32
I sorted by path asc or desc, same issue.
Posted: 03 Jun 2020, 00:09
by Administrator
I still dont understand what is wrong with sorting at your screenshot?
Posted: 03 Jun 2020, 08:16
by mz1888
It jumped from sub1 to sub2, then back to sub 1. It's expected when sorting by path, it goes sub1 then sub2 and not back again.
Posted: 03 Jun 2020, 09:26
by Administrator
For me everything looks correct.
i guess you are confused by the sorting order ascending and descending?
You are sorting a flat list and not a hierarchical structure like a tree view...
Posted: 03 Jun 2020, 13:21
by mz1888
From your screenshot, the ascending ordering on the path is hierarchical thus correct, when the file names are identical.
From my screenshot, it shows path sorting is disrupted i.e. non-hierarchical when filenames are dis-similar. The only way this makes sense is that AllDup aggregates all files in one list ordered by filename, look up similar files sequentially, and dumps the output as is. And the path ordering is done within the grouping, not between the grouping.
If sorting by path is working as perceived by average users, we'd see sub-folder hierarchy: 0, 1, 2,....,n-1, n, not 0, 1, 3, 1,...n.
Posted: 03 Jun 2020, 18:45
by Administrator
the sorting is always based on the content of the column cells.
in case of the path column its a flat list with text strings that will be sorted (ignoring case).
Posted: 04 Jun 2020, 06:22
by mz1888
It's not exactly a flat list. If you sort by group, it will sort by the filename referenced by the group. However, if you sort by path, only the path within the group would change and the groups would remain unchanged.
Is it possible to add tree view as an additional feature? introduce additional grouping on top of the filename grouping, or, allowing moving path column before the filename.
Posted: 04 Jun 2020, 17:37
by Administrator
mz1888 wrote: 04 Jun 2020, 06:22Is it possible to add tree view as an additional feature?
There is already a tree view at the first column.
Maybe we will add a multi-column sorting style like this:
https://www.grapecity.com/wijmo/demos/G ... umnsorting
We already tested this but the grid gets "confused" internally when the position of the tree view with the groups is not inside the first column...
Posted: 05 Jun 2020, 04:48
by mz1888
Yes please and thank you. The FlexGrid would put AllDup way ahead of the curve.
Posted: 17 Feb 2022, 23:17
by JoBeCo
mz1888 wrote: 02 Jun 2020, 08:50
I'd like to pull this up again. Actually there is no chance to sort the whole result table by path.
As shown in the screenshot there are three groups. Sorting by path-column should also change the order of the groups. So the total list could be examined and inspected in path order.
Example (nearly the screenshot):
Group 1
\a\a
\a\a
Group 2
\a\b
\a\b
Group 3
\a\c
\a\a
Ascending Sort:
Group 1
\a\a
\a\a
Group 3
\a\a
\a\c
Group 2
\a\b
\a\b
So the sorting you implemented takes place in group 3 but also group 3 needs to be placed above group 2. With the same paths in the first row groups 1 and 3 could also be sorted the other way ...
Cheers,
JoBeCo
Posted: 19 Feb 2022, 10:34
by Administrator
JoBeCo wrote: 17 Feb 2022, 23:17
Sorry, this is not possible...
