Page 1 of 1
Different Colors in Search Results
Posted: 01 May 2020, 08:01
by tpiddy
Hi, after searching, and getting some search results, one if the duplicates filename and path is a different color, like a yellow. What does that represent. I tried my best to search for the answer, but I am finding nothing. Thanks!
Re: Different Colors in Search Results
Posted: 01 May 2020, 12:34
by Administrator
See search result -> menu bar -> options -> colors
Posted: 26 May 2020, 02:00
by mz1888
Very useful feature although I had issues when keep changing the colors. The colors didn't seem to change with my selection...
Posted: 26 May 2020, 09:04
by Administrator
Changing the colors at the options doesnt change the existing colors at the search result.
Color Scheme — FIX it, please!
Posted: 11 Jun 2020, 23:51
by «G~Lí†çh»
Another computer, another theme (more compatible), but... just look at this space waster:
BTW, to save GUI space AllDup must combine columns:
if {"Search Criteria" (%Size%, %File_Content%) was ON &
columns[Filename | path] placed (after, before) columns[%Size% | %Duplicates% | %Sample_rate% | %Bit_rate% | %Duration% | %Width% | %Height%]
do {combine these columns for a path or a filename}
Posted: 12 Jun 2020, 15:33
by Administrator
The color display problems when using a dark windows theme was fixed overall in the program with the next update.
The wrong column header title height was fixed too.
We also added the option 'Ignore column header text when optimizing width' to resize only the content of the columns without using the column header text.
Posted: 25 Jun 2020, 16:42
by «G~Lí†çh»
Oh, I expeted that the new version is correspond Windows color scheme, but it doesn't:
I want to remove WHITE color at all!
Tried different "User Interafces": Design 1, Design 4 — all the same. (Why I can't change interface options while search in progress?)
Resize Date/Time Columns:
Posted: 25 Jun 2020, 17:00
by Administrator
«G~Lí†çh» wrote: 25 Jun 2020, 16:42
Oh, I expeted that the new version is correspond Windows color scheme, but it doesn't: I want to remove WHITE color at all!
Sorry, thats not possible.
