Shortcut manager with exit option - redux
Posted: 04 Feb 2005, 00:56
AllSync 2.2.20 - Business Ed.
Win2k Pro
When using the Shortcut Manager with:
1. Run Mode: Perform copy operation and exit
2. Options: Display start up window for copy operation
It would be a nice addition if:
1. The copy operation would abort as well as not shutting down windows when the destination drive is not found. For example, the other day the firewire cable to my external hard drive became un-plugged which resulted in the destination drive not found; the copy operation never ran and Windows shut down automatically - I did not realize there had been a problem until a few days later.
2. If you press the cancel button on the start up window, then Windows should not shut down
but you already know about that one
Win2k Pro
