Compare with same properties
davidsrothman
Post by davidsrothman »
It seems that when "file extension" is checked it considers case, so ".jpg" is not equal to '.JPG". Seems like case should be ignored (or at least case sensitivity should be noted in the program)? (note: i didn't check this for "file name").
Re: Compare with same properties
The search for the same file extension is NOT case sensitive.
