Ignore everything after specific character " ) "
rosgr100
Post by rosgr100 »
Hi, i would like to ignore every text after the bracket ")" how can i do that?
Thanks!
Re: Ignore everything after specific character " ) "
At what point?
As a part of the initial file search process?
As part of selection process of the results?
rosgr100
Post by rosgr100 »
therube wrote: 17 Nov 2019, 19:31 At what point?
My bad sorry, during the search process!
Depending on what follows the ), you might be able to get away with:
Search Method -> File name -> Find similar file names
with one of the Algorithms listed there (check the Help for specifics).
(If the Ignore options allowed RegEx... but they don't.)
(When I first looked at this thread, yesterday, I & until the moment I was about to make this reply, thought I was in the Bulk Rename Utility forums, heh.)
ahmetgns
Post by ahmetgns »
Yes, it would be good for search options to have "Ignore text before specific character" and "Ignore text after specific character" options.
But if wildcards could be used in "Ignore certain characters.."* or "Ignore certain strings.."*, then new options suggestin above will not be necessary.
(*) By the way, these fields are CaSe sensitive but not declared in the help file. Even it would be good also if options for case-sensitivity are present there.
