Feature request for Data Protection.
js.mulree
Post by js.mulree »
I backup all of my data onto a network share using the 1:1 copy option and store changes in a folder on the same network share. This network share is read-only usually so my backups are less likely to become corrupted, but I provide a username and password for the network share within AllSync to enable writing. This works fine for the backup process since I can specify a username and password, but this does not work when specifying the location for Data Protection since there is no option to provide a username and password for that location. Presently I am mapping the network share as a network drive within AllSync, but I would rather use the network path rather than a network drive.
So my feature request is to be able to specify a username and password when specifying the location for the Data Protection.
Thank you for such an outstanding product!
Cheers :D
Re: Feature request for Data Protection.
Sorry for the late response. I have note you request to our ToDo-List for further updates!
js.mulree
Post by js.mulree »
No need to apologise, I really appreciate you responding to my request! In fact, I really should apologise for failing to post in the English forums.
Cheers :D
