Why can't I select more than one destination folder?
madrum
Problem syncing to multiple destination folders
Post by madrum »
I need to sync folders across servers so I've specified:
\\server1\reports
\\server2\reports
\\server3\reports
... as my destination folders.
Why can't I select more than one destination folder? Is there a work-around for this bug?
Re: Problem syncing to multiple destination folders
madrum wrote:Why can't I select more than one destination folder? Is there a work-around for this bug?
This is by design and not a bug. Please create a separate profile for each destination folder if you use the copy mode sync.
madrum
That'll work
Post by madrum »
That's a little more work but it's a one time setup.
:idea: If you can't select more than one checkbox in an area, there shouldn't be checkboxes there in the first place. That's what radio buttons are for.
Re: That'll work
madrum wrote:If you can't select more than one checkbox in an area, there shouldn't be checkboxes there in the first place. That's what radio buttons are for.
Yes, i know, but unfortunately the list view control we use doesnt support radio buttons. I note this to our ToDo-List.
