The module "axvlc.dll" failed to load
FireMarshalBill
Post by FireMarshalBill »
I followed these instructions exactly.
Manual integration of the VLC Media Player:
Open the FTP archive at the official website of the VLC Media Player.
Scroll down to the end of the FTP archive, click on the folder with the latest version number (e.g. "3.0.16") and then click on the folder "32bit".
Download the file with the "zip" extension (e.g. "vlc-3.0.16-win32.zip").
Extract the following files and folders from the ZIP file into the folder of AllDup:
files: axvlc.dll, libvlc.dll, libvlccore.dll
folder: plugins
Run AllDup with admin rights once to register the file axvlc.dll at your Windows system automatically or register the file axvlc.dll at your Windows system manually using the command: regsvr32.exe axvlc.dll
In fact, I had the 64-bit VLC installed on my 64-bit machine. As I got this error, I uninstalled it and reinstalled the installer I downloaded from your archives, copying the three files again to the Alldup folder. Same issue. Using Windows 10.
TIA
Re: The module "axvlc.dll" failed to load
try to register the file axvlc.dll including the path were your saved the file:
regsvr32.exe C:\Alldup-Dir\axvlc.dll
