Deleting the files.
Pocketrace
Deleting the files.
Post by Pocketrace »
It's my first day using Alldup and I scanned 3 times my Music folder and I get always the same result.
But after every search I delete all the files that I do not want. But it seems it deletes them from the software but not for real.
What I am doing wrong ?
Eric Robidoux a guy with too many duplicate songs.. :D
Re: Deleting the files.
How do you delete them? Do you use AllDup's file manager?
Pocketrace
The problem is the software was installed in French.
The first time I selected the files that I wanted, then I went into "Supression" and I picked "Supprimer tous les fichiers selectionnés" It deleted in Alldup the good files but not in the source folder
The second time I selected the files that I wanted, then I went into "Supression" and I picked "Supprimer de facon recursive, tous les fichiers d'un dossier specifique", then I picked My Music folder It deleted all the files
Pocketrace
Ok I found the file manager.. Sorry
Sissou100
Post by Sissou100 »
Hello,
I have the same problem.
When I click on : “Suppression” (software in French)
Then: "Supprimer les fichiers sélectionnés" (“Delete selected files”)
The files disappear and there's only one file left per group (which is what I want)... But, in fact, all these files are still on the hard disk. If I run the search again, they appear again and the disk space doesn't move.
I'm having trouble understanding the software's logic.
How can I (really) delete a selection of several thousand files?
Could you please explain the procedure?
THANK YOU in advance for your help.
Sissou100 wrote: 20 Feb 2025, 23:40 When I click on : “Suppression” (software in French)
It looks as if the French translator misunderstood the English text and therefore mistranslated it.
I guess your used the command “Remove selected files” but the translation is “Delete selected files”...removing something form a list doenst mean you delete the file.
Just use the file manager to delete the selected files in your search result.
Sissou100
Post by Sissou100 »
Hello,
Thank you very much for your prompt reply.
Could you please be more precise when you talk about file manager? Where is it? How do I open this file manager?
Sissou100
Post by Sissou100 »
I just found the button. THANK YOU again for your help and the time you spent answering me.
Have a nice day!
