Thank you for the latest release and the speed improvements I recommend in my last email. (deleting paths from list without animations)
Since the latest version I have problems to mark files in the duplicate files result list with the same path.
In the past it works perfect.
Here is a screenshot of the menu entry, which I tried to use. Nothing happend after I click on it.
First I though it is a problem, because the pathname is very long. But it also happened with short paths and filenames with alphabetic und numeric characters.
Alldup 4.5.62 - Selection of files from the same path does not work
Re: Alldup 4.5.62 - Selection of files from the same path does not work
The context menu command "Select all files with the same path" works here without any problems.
How long?the pathname is very long
You are right!
I did an uninstall und new install of the software and now it works again!
Strange. Thank you for your hint.
