Any way to compare Track Duration too?
rosgr100
Post by rosgr100 » 02 Mar 2020, 06:49
Hi, I'd like to ask if there is any way to compare track duration while i compare file names of music files.
Thank you.
User avatar
Re: Any way to compare Track Duration too?
Post by Administrator » 02 Mar 2020, 09:35
No, thats not possible.
rosgr100
Post by rosgr100 » 02 Jun 2020, 07:19
Administrator wrote:
02 Mar 2020, 09:35
Hi, is there any chance to add Duration as a Comparison criterion, it would be really helpful.
mz1888
Post by mz1888 » 02 Jun 2020, 08:53
Maybe just display in the search results but don't actually add to comparison? such a feature would work so great with video files too. Also, allow video file audio tracks to be compared in this way.
User avatar
Post by Administrator » 02 Jun 2020, 15:28
I will add this to our ToDo-List:
- comparison criterion sound/video duration
- add column duration at the search result
rosgr100
Post by rosgr100 » 03 Jun 2020, 18:28
02 Jun 2020, 15:28
Thank you. This will save some time for me, because now i have to check all the results to be sure that only the tracks with the same duration will be deleted.
I have one more question. due to some audio files being one or two seconds shorter or longer although the track is exactly the same is there any chance to add a setting for percentage match for duration criterion?
User avatar
Post by Administrator » 03 Jun 2020, 18:56
there is already a column with the duration available:
rosgr100
Post by rosgr100 » 03 Jun 2020, 19:32
03 Jun 2020, 18:56
Yes there is, and you are able to determine duration during the search (there is an option to enable that).
This is what i'm doing now i check them manually, but if this was an automatic process it would be way faster and easier. :mrgreen:
User avatar
Post by Administrator » 03 Jun 2020, 22:39
The new "Audio" comparison criterion:
did i miss any important media file types?
rosgr100
Post by rosgr100 » 04 Jun 2020, 03:52
03 Jun 2020, 22:39
Perfect!!! Thank you for this, it will save so much time for me, you rock guys.
If it is possible to add a percentage match or something like 2-3 seconds difference to be considered as equal track to others this feature will be completed for me.
Any way once again thank you for the implementation.
User avatar
Post by Administrator » 04 Jun 2020, 09:33
Screenshot - 04.06.2020 , 09_26_48.png (6.83 KiB) Viewed 2253 times
rosgr100
Post by rosgr100 » 04 Jun 2020, 17:34
04 Jun 2020, 09:33
Perfect!
You are the best.
Thank you! 👏👏
rosgr100
Post by rosgr100 » 08 Jun 2020, 19:52
Hi,
Any chance for a release date for the 4.4.29?
Can't wait for it... :lol:
User avatar
Post by Administrator » 08 Jun 2020, 20:31
I guess this week.
A lot of work to do because of the revamp of the search method selection:
rosgr100
Post by rosgr100 » 08 Jun 2020, 20:44
08 Jun 2020, 20:31
I guess this week.
Thank you for the update.
One more question.
About the option you are showing above, will this compare filenames and lengths or just lengths?
