Exact Copy of File/Folder Structure
robinbrittain
Post by robinbrittain » 20 Aug 2014, 22:01
Hello,
I have AllSync Version 3.5.64, Home Edition. I would like to use it to copy files and folders exactly with their structure and file attributes and permissions etc.. from a computer across a network to a NAS unit. Are there any settings I should be changing in a default profile, such as with the 'Copy Rules' so that everything is replicated exactly as a mirror copy? For example, I can see the option for 'Transfer access permissions of files and folders'. I'm not sure if this should be ticked. I did a quick test of a few files and folders, but couldn't see looking at file properties what difference it made with this option enabled. Though I only did do a quick test. It is important that I copy everything exactly the same including file attributes and permissions. However I can see the latter maybe a problem as the source files which are from an MS Windows PC, NFTS files system are being copied to a NAS unit, Linux system.
Many thanks.
Regards,
Robin.
User avatar
Re: Exact Copy of File/Folder Structure
Post by Administrator » 26 Aug 2014, 22:37
The copy mode "1:1 copy" should do the job.
btw: You can't transfer windows permissons to a NAS drive.
