Remove all groups with any files selected
effsync
Post by effsync » 15 May 2020, 01:53
I see AllDup can Remove all groups with all files selected. Can it Remove all groups with any files selected?
User avatar
Re: Remove all groups with any files selected
Post by Administrator » 15 May 2020, 07:33
any = some files selected at a group?
effsync
Post by effsync » 15 May 2020, 12:05
Yes, if one or more files are selected in a group.
User avatar
Post by Administrator » 15 May 2020, 13:11
Ok, i will add your suggestion to our ToDo-List:
"Remove all groups with some files selected"
I used the word "some" because this command will not remove groups with all files selected.
Correct?
effsync
Post by effsync » 16 May 2020, 03:55
That's perfect! Thank you!
User avatar
Post by Administrator » 19 May 2020, 09:47
New update with the new remove command is available!
effsync
Post by effsync » 21 May 2020, 03:41
It works great! Thanks!
