Fail to start AllDup on Windows 10
wildcatquebec
Post by wildcatquebec » 04 Feb 2020, 23:58
Hello,(sorry for my english)
I want to execute alldup on Windows10 but it fail to run.
I install the last version with sucess but when i try to execute it
The MSIINSTALLER start and try to install Autocad 2018. (Its alreally installed) it fail with a message : "Run Setup.exe to install Autocad2018"
The Portable Version : Same Problem.
Run as a Administrator : Same Problem
Try to run as Windows 7 (Compatibility ) : Same Problem
I just cannot start AllDup.
If someone can help mw this this it will be appreciated
Thx :)
Re: Fail to start AllDup on Windows 10
Post by therube » 05 Feb 2020, 00:31
How are you trying to start AllDup?
Desktop shortcut?
Right-click the shortcut, Properties.
What does the Target: box show?
If you browse (Windows Explorer) to wherever AllDup.exe (AllDupPortable.exe) are & click on them, will AllDup run?
What version of Win10?
wildcatquebec
Post by wildcatquebec » 05 Feb 2020, 02:33
Desktop / Start menu / double click on it
it try to launch a installation of Autocad 2018 (its fail) and i must kill ALLDUP.exe from the taskmanager.
Target :
C:\Program Files (x86)\AllDup\AllDup.exe
Windows Version :
Windows 10 Entreprise
Its look like a problem with MSIINSTALLER but why it trying to execute it when i start alldup
User avatar
Post by Administrator » 05 Feb 2020, 10:54
This is the self-repair mechanism triggered automatically by the OS (Windows Installer Service).
You can deactivate the Windows Installer Service and the popup will not show again
or you reinstall Autocad2018 to fix it.
More information about the MS installer problem:
https://www.google.com/search?q=Windows ... app+starts
