How do I eliminate a single file in the search results
davekstl
Post by davekstl » 26 Oct 2019, 21:26
After I remove or move search results files, how do I filter out or auto mark files so I no longer have to review that result. Is there a refresh without searching again?
Dave
User avatar
Re: How do I eliminate a single file in the search results
Post by Administrator » 27 Oct 2019, 08:30
Use the menu command "Remove all non-existing files from the search result". See menu bar -> Remove.
davekstl
Post by davekstl » 28 Oct 2019, 17:54
There would be just a single file left, but it shows as a single file. I do not want to delete the remaining file, is this still the function of "Remove all non-existing files from the search result"? It will leave the single remaining file correct?
User avatar
Post by Administrator » 28 Oct 2019, 20:14
Only files that exist will be left at the search result using this command.
