#5 - Access Denied [SetFileSecurityWide]
hdegenaro
Post by hdegenaro » 22 Jun 2013, 01:11
Hello,
I'm not accomplishing my backup routines, after I reinstalled Windows. I am running Windows 8 Professional x64, with the version 3.5.64 of AllSync. I am getting the following error: #5 - Access Denied [SetFileSecurityWide]
I start the application as administrator and even then get this error. Can anyone help me?
Thank you.
User avatar
Re: #5 - Access Denied [SetFileSecurityWide]
Post by Administrator » 22 Jun 2013, 18:06
1. the file access is blocked because a other software uses this file
2. the user of AllSync dont have enough access rights to the change file. to be a windows admin doesnt mean you have all rights at your system.
hdegenaro
Post by hdegenaro » 24 Jun 2013, 22:04
Hi,
When I used Windows 7, I had this problem. Now in Windows 8, you know how I can solve this? Should I configure something else in AllSync?
User avatar
Post by Administrator » 25 Jun 2013, 00:38
try this:
1. make a copy of the file
2. delete the file
3. restore the copied file
or:
deactivate the copy rule "Transfer access permissions of files and folders"
hdegenaro
Post by hdegenaro » 25 Jun 2013, 02:52
Hello,
I disabled the "copy rule" and it worked... thank you very much !
