Using Data Protection with a User Defined Copy Mode
jeffhobbs
Post by jeffhobbs » 06 Nov 2008, 01:36
Hi,
I'm running a user defined copy mode with the "Move Source Files to Destination" checked. I also have the copy protection set. The hope is that the moved files would be backed up in a directory on the source location and then moved to the destination.
When I run the profile nothing is backed up however the source files are moved to the destination. Any ideas on how to accomplish my goal here?
Thanks,
Jeff
User avatar
Re: Using Data Protection with a User Defined Copy Mode
Post by Administrator » 06 Nov 2008, 02:15
What version of AllSync are you using?
Have you activated the data protection "Move items to a backup folder" and the option "Data to be moved"?
jeffhobbs
Post by jeffhobbs » 06 Nov 2008, 02:48
I'm running 2.7.41.
I do have the "Move items to a backup folder" checked. I don't know where the "Data to be moved" setting would be located. Is that on my version?
User avatar
Post by Administrator » 06 Nov 2008, 02:50
Sorry, this option is only available with AllSync version 3.x...
jeffhobbs
Post by jeffhobbs » 06 Nov 2008, 02:52
So, are you saying that I don't have a way to do what I'm trying to accomplish with 2.7.41 but I do with 3.x?
User avatar
Post by Administrator » 06 Nov 2008, 04:26
Yes, this new feature is only available with version 3.
