Copy Operation Options
mtn_roadie
Post by mtn_roadie » 04 Jul 2008, 04:20
When you are running a copy operation, there are a few options to choose, i.e.:
Set application priority to 'low'
Reduce the number of hard disk accesses per second
And:
Upon completing the copy operation:
  • Shut down computer
  • Shut down Windows
  • etc...
What is the difference between "Shut down computer" and "Shut down Windows"?
User avatar
Re: Copy Operation Options
Post by Administrator » 04 Jul 2008, 16:09
Shut down computer:
Shuts down the system and turns off the power. The system must support the power-off feature.
Shut down Windows:
Shuts down the system to a point at which it is safe to turn off the power.
